8 years agoNIOS II/s hang and jump to exception
Hi, I'm using NIOS II/s on CyclonV. My system contain 2 uarts (Baud Rate 115200) and one timer which tick every 20mSec. From time to time the nios hang and only restart help. When using ...
8 years agoHi,
I found out that each time I change the NIOS code it change the behavior of the "hanging" So it's hard to find the root couse. The thing that solved the problem was: 1. Shorting the time the nios spent in interrupt to minimum. 2. I found a line in the code that read from memory that not exist. Good luck, Erez
