15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoThere are some screenshots that I took:
Block Diagram File, showing the PLL: http://img696.imageshack.us/img696/519/nios.th.png (http://img696.imageshack.us/i/nios.png/) Configs I tried: 1. c0: 50Mhz -3ns [SDRAM] (cpu directly connected to system clock) 2. c0 :50Mhz -3ns [SDRAM] c1: 100Mhz 0ns [CPU] 3. c0: 100Mhz -3ns [SDRAM] c2: 100Mhz 0ns [CPU] I tried even to create the PLL inside the SOPC, same results. SOPC configuration: http://img130.imageshack.us/img130/4353/sopc.th.png (http://img130.imageshack.us/i/sopc.png/) The adresses are all below 0x0100 0000 for the components, except for sdram, which is at 0x1000 0000. When I modified the clock fed by the PLL, I accordingly changed the clk. CPU config: http://img207.imageshack.us/img207/8817/sopc2.th.png (http://img207.imageshack.us/i/sopc2.png/) I've tried different values for reset and exception vector, including the ofsset 5000000 cited here in some thread. If you need more screenshots, or the entire project, I will promptly upload. Thanks in advance
