15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoDaixiwen,
This is really puzzling me. I'm not experienced in VHDL or Verilog. I've built the system in a Block Diagram File, following instructions from the book cited. It is really simple. It has a nios2 block and a PLL block. To each of them I wired several input/output/bidir ports. Then I assigned the pins in the Assignment Editor. When I configure the PLL with one 50Mhz, -3ns output (to the SDRAM) and wire the native 50MHz clock directly to the clk of the Nios II, I'm able to configure the FPGA, upload a File to the SDRAM but not run the file (it doesn't VERIFY the sdram) When I configure the PLL with two outputs, one of them 50 MHz -3ns (to the SDRAM) and the other 100MHz without delay (to the clk of nios2), the processor freezes (it PAUSES, and cannot be unpaused). So I strongly suspect that I'm not using the PLL well. Or I am doing something really really dumb and not seeing it. I'm trying everything that I find, but with no success. About your questions: I do not declare the clock anywhere, and don't know how to constrain inputs/outputs. If you give me some pointers on that I would really appreciate. The only reference designs that I have (for the DE2-35 board) are the ones provided by the book. But they do not use MMU, and use really old components (7.1) for Nios. I have several others references, but they're both not for DE2 and not a BDF file. Would be better if I make the system in verilog, instead of a Block Diagram File? dsl, I tried -3ns and -4ns for the SDRAM, I will try 3.4ns and other close values. Thank you people for the help.
