15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoThe .sof generated is not time limited, I use a license file properly configured.
I provide a 100Mhz clock to the processor. I pick the native DE2 50 Mhz clock (PIN_N2) and pass through a PLL to double the frequency. The clock to the SDRAM chip is 50Mhz phase shifted -54 degrees by the same PLL. I would post a screenshot, but Altera forum wouldn't let me. Regarding the RESET signal, I changed from a push button to a switch, with no success on both positions of the switch. I know the problem isn't the chip because I can use other precompiled nios2 with success. I will try other clock setups and see what happens. Also, I have one doubt that's bugging me. After I generated the processor and put on the .bdf file, I created all of the input/output/bidir portsby hand (I know now that this can be done automatically). But when I open the Assignments Editor, only the pins of the nios2 block appear, and none of the ports. Is this normal? I had to manually enter the names of the ports. Thanks
