13 years agoNios II with on-chip Dual port ram between Nios and External DSP
Hello, I'd like to implement a dual port ram using on chip memory, with one side connected to the Avalon bus and other connected to an external DSP. Not sure where to get started; I can not se...
13 years agoYou are mostly correct, except how "dummy" your module is depends on how (dis)similar your DSP memory controller is when compared to Avalon-MM.
If you want to skip creating the Qsys component, you can simply "export" the second (s1) port of the dual port RAM. When you do that, in your top level module you will get a series of signals like this:
unsaved u0 (
.onchip_memory2_0_s2_address (<connected-to-onchip_memory2_0_s2_address>), // onchip_memory2_0_s2.address
.onchip_memory2_0_s2_chipselect (<connected-to-onchip_memory2_0_s2_chipselect>), // .chipselect
.onchip_memory2_0_s2_clken (<connected-to-onchip_memory2_0_s2_clken>), // .clken
.onchip_memory2_0_s2_readdata (<connected-to-onchip_memory2_0_s2_readdata>), // .readdata
.onchip_memory2_0_s2_write (<connected-to-onchip_memory2_0_s2_write>), // .write
.onchip_memory2_0_s2_writedata (<connected-to-onchip_memory2_0_s2_writedata>), // .writedata
.onchip_memory2_0_s2_byteenable (<connected-to-onchip_memory2_0_s2_byteenable>), // .byteenable
.onchip_memory2_0_clk2_clk (<connected-to-onchip_memory2_0_clk2_clk>), // onchip_memory2_0_clk2.clk
.onchip_memory2_0_reset2_reset (<connected-to-onchip_memory2_0_reset2_reset>) // onchip_memory2_0_reset2.reset
which maybe is close enough for your system.
