15 years ago
Nios II with integrated DCFIFO problem
Hi guys,
I'm fairly new to FPGAs and in particular Altera stuff so please excuse any naive comments I might make. I'm having a problem getting a FIFO to work with the Nios II processor so that I can interface to an imaging sensor. I've been trawling the web and the forums for an answer but alas to no avail...
Firstly does anyone know of an example/development kit project/tutorial which implements an example of a FIFO interfacing to an off chip peripheral on one side and a Nios processor on the other? An example is always helpful.
Right the procedure I have followed is:
I've instantiated the SOPC FIFO as a DCFIFO with an avalon-MM interface on one side and an avalon-ST sink interface on the other. I don't have any status interfaces on the read or write side. The MM (read) side is connected to my CPU.
I've then created a custom peripheral and used the templates to create an avalon-ST data source. This is then connected to the ST side of the FIFO.
I've then generated the system and when I bring it into verilog I get a bunch of exported signals from the ST source which then allow me to write to the custom peripheral.
Is this a logical way to go about implementing what I want to do? Or is there a problem with the custom peripheral in this format?
I then run the following code to try and read the FIFO:
#define DATA_BASE (alt_u32) 0x00005040
# define WRREQ_BASE (alt_u32) 0x00005050
# define FIFO_BASE (alt_u32) 0x00005068
# include "sys/alt_stdio.h"
# include "altera_avalon_fifo_regs.h"
# include "altera_avalon_fifo_util.h"
int main(void){
unsigned short n=0;
n = altera_avalon_fifo_init(FIFO_BASE,0,0,0);
alt_printf("%d\n",n);
while(1){
n = altera_avalon_fifo_read_fifo(FIFO_BASE,0);
return 0;
However when I write data to the FIFO I just get nothing coming out in the console....
I'm not really sure though that I'm using the initialise command correctly. If all this is correct then I guess I must have a problem with my data input.
Thanks in advance for any help =).
Richard
