14 years agoNIOS II SBT problem
Hi all, I am using NIOS II SBT v11.0.I am not able to create new project in NIOS II SBT.Every time I am getting "Failed to execute ./create-this -app --no make." error and I am not able to cre...
14 years agoHi all,
I have figured out one possible solution of the issue.I am using Windows7 and I haven't selected Windows7 under compatibility mode.To select it follow the procedure. Right Click on Nios II 11.1 Software Build Tools and select properties. Select Compatibility tab. Select Windows7 under Compatibility mode. Restart PC. I hope this will help you. Regards, Krupesh.
