22 years agoNios II max clock speed
Hi nios gurus, Does anyone know if the nios II is capable of running in the 123MHz range? I am using a nios I design with a cyclone dev kit currently and would like to step up to nios II. I'...
14 years ago --- Quote Start --- The reason for this is that i have built a small verilog module that is hooked up to the nios via the avalon bus and so am not allowed to feed it a faster clock speed without requiring the overall system to be picked up as well. Unless there is a way??? I don't know. Is there a way to run an external module with a separate clock speed and still be able to interact with the nios avalon bus? --- Quote End --- Use the Avalon MM Clock crossing bridge.
