22 years agoNios II max clock speed
Hi nios gurus, Does anyone know if the nios II is capable of running in the 123MHz range? I am using a nios I design with a cyclone dev kit currently and would like to step up to nios II. I'...
22 years agoGreat thanx for the info James,
Sounds like the niosI on a cyclone fpga can achieve what i am after. Theonly thing left I need to worry about is the interactions of the other components on the cyclone dev kits such as the sdram. On my system, the cache is not really that important right now so I can give a little bit back in that department. But the clock speed is very incouraging!! thanx again, -Quan
