12 years agoNios II Gen2 core error
I just migrated my nios II to Nios II Gen2 core. I got a error as below. i tried to set instruction and data cache size to none. still give same error. /HAL/src/alt_remap_uncached.c:52: warning...
11 years agoI see now, yes the message is quite explicit telling you what your problem is:
* Convert a pointer to a block of cached memory into a block of uncached memory.
* Return a pointer that should be used to access the uncached memory.
* This routine was created for Nios II Gen1 cores which allow mixing cacheable and
* uncachable data in the same data cache line. So, they could take any memory region
* and make it uncached. However, Nios II Gen2 cores don't support mixing cacheable
* and uncachable data in the same data cache line so require the memory region to
* be aligned to a cache line boundary and must be an integer number of cache line
* bytes in size. So, software on a Nios II Gen2 core shouldn't really be using this
* function so it fails with a link error.
volatile void*
alt_remap_uncached(void* ptr, alt_u32 len)
/* Generate a link time error, should this function ever be called. */
ALT_LINK_ERROR("alt_remap_uncached() is not available because Nios II Gen2 cores with data caches don't support mixing cacheable and uncacheable data on the same line.");
return NULL;
