15 years agoNIOS II Flash works but not on cold reboot
I am working on a Cyclone III board that is a custom layout and I am having issues getting it to work as it should from a cold reboot. I have no issues in Quartus 10 compiling and programming v...
15 years agoWhat's your flash device? epcs?
Does Nios reset address match flash base address? Otherwise fpga will configure correctly but Nios won't boot. This seems to be your situation. It could also be a problem related to bootloader. While jtag automatically loads all memory sections, when you boot from flash the bootloader must take care of this. Do you use a single memory (sdram, onchip ram, ...) or do you have more devices? Any tightly coupled memory? Another error which could cause such a behavior is a mismatch between the fpga configuration you flashed and the one required by Nios firmware, but I guess you already checked this point.
