MGhad3
7 years agoNios II flash programmer error
I get the error below during flash programming the elf file using the Nios II flash programmer. what is the reason?
Error code: 4 for command: nios2-flash-programmer "C:/CyclonV/C5_epcs_flash_controller_0.flash" --base=0x10000000 –epcs --accept-bad-sysid --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose
- Ahmed_H_Intel1
Hi, The NIOS II flash programmer tool isn't recommended any more, can you please use one of the recommended procedures? The JTAG Indirect Confoguration procedure .jic file or Parallel flash programmer procedure I am sharing an example of using these two procedures to program the serial or parallel flash device: - Ahmed_H_Intel1
- Ahmed_H_Intel1
