10 years agoNIOS II: everything in "system ID properties" is "not found"
Hello Everyone, I'm a beginer in FPGA and Softcore NIOS II. I'm trying to get a "Hello world small" program work. I followed all the steps you will find in the attached file "BE_Controle_CV...
9 years agoThanks for your help mnguyend!
I am trying to follow your instructions: --- Quote Start --- Solution (what worked for me).. I went back and read the portion about setting up nios in qsys and noticed that it specifically said to "uncheck initialize memory content... you will initialize the software executables from Eclipse." I did that and went through the whole process again and was able to successfully see 'hello world' again. Have a go and good luck! --- Quote End --- Which window/setting did you find the box to "uncheck initialize memory content"? Thanks, Vinny
