CKaru
8 years agoNIOS II ELF Download error on 10AX115N4F40I3SG
I am working on a NVME project on Reflex RXCA10X115PF40-PROD Dev kit. The FPGA device on the board is Intel® Arria® 10 GX FPGA 10AX115N4F40I3SG. I use Quartus prime version 16.0.2 Build 222 07/20/201...
CKaru
8 years agoThanks Anand. I am maintaining the same pin assignment in both working board with ES2 device & the problematic board with prod fpga. Except the fpga device installed all the others , including dip switch settings, are same in both boards.
The external reset pin of the design is pin mapped to a push button which is pulled-up to 1.8V rail. So the reset is activated only when the push button is pressed.
The reset is connected to a pll ipcore & it's reset output is connected to all other ipcores , including the NIOS II, in the design.
