9 years agoNios II Eclipse in Windows 10
I just got a new machine with Windows 10 64-bit. I previously had win 7 64 bit installed with Quartus prime 15.1 installed. I tried installing Quartus prime 15.1 on the windows 10 box. It installed. ...
8 years agoNo, I still have to perform a build all and then run the .sh file as described above in the command shell in order to produce a .elf file. I also had to add a elf2hex command and a alt-file-convert command to the .sh file in order to produce a .hex file because the make targets mem_init_generate doesn't work properly in windows 10 either.
