14 years agoNios II Data cache bypass
Hello, I've created a SOPC component, where Avalon-MM slave port is connected directly to the Dual-Port RAM (1 read port, 1 write port). The hardware writes to the DPRAM and I want to reach that d...
14 years agoDon't forget that this trick will only work as long as you don't use MMU. If you want your code to be portable to a MMU architecture in the future, you might consider using the alt_remap_uncached() function instead of changing bit 31 on the pointer.
