15 years agoNios II C/C++ Application and BSP Template not found
Hi, I am using 10.1 version of Nios II Eclipse and I am not able to create Nios II C/C++ Application and BSP Template. When I click New to create an application, it does not give me the option...
14 years agoYes :
If you don't see a NiosII menu item on Eclipse, or File => Run -> Nios II C/C++ Application and BSP from Template Un-install all Altera packages, delete all Altera files, reboot, re-install NiosII with Eclipse. Then one should have the NiosII menu items, including "Nios II C/C++ Application and BSP from Template". Run Eclipse in XP sp2 compatability mode. I have administrator privileges. Say yes if get a run confirm window. Then run "Nios II C/C++ Application and BSP from Template". Should now run through OK. Build Application (right click). Use NiosII => Quartus II Programmer menu item to connect to hardware, upload .sof file. Run application as NioII Hardware, making sure you refresh the USB connection if needed (on extreme right of window if pops up). Should now all run. Best of luck.
