14 years agoNios II Building Error
I got this error when building a Nios II project. Please help me fix it. :)
alt_sys_init.c:(.text+0x8): warning: Error: Interrupt not connected for JTAG_UART. You have selected the interrup...
14 years agoFirst you need an onchip memory in your system, connected to both the Nios CPU's instruction and data masters. Then in the BSP settings, set all the memory configurations to your on-chip memory. If the memory is small, select the small C option, and enable the compiler optimisations.
