VKoto
7 years agoNIOS II boot from QSPI
Hello, I have a problem with booting NIOS from QSPI. If I set booting NIOS from on-chip flash everythink is OK. But If I set booting from QSPI according AN730 – boot option 4a NIOS doesn‘t boot. I w...
GuaBin_N_Intel
Contributor
7 years agoWhich serial flash controller and flash memory are you using? To narrow down the issue, you may try out standard mode (x1) and lower the running freq.
