15 years agoNios II - Data cache problem
Hi all, I'm using a Cyclone III DSP Kit (DK-DSP-3C120N) and uClinux. Some days ago I realized a working design which includes a Nios II processor characterized by only an instruction cache. Wi...
14 years agoIIRC you normally use the return value from ioremap_nocache().
- it returns NULL on failure. Doing a memset() on device registers isn't necessarily a good idea either. You probably want much more control over the actual bus cycles used.
