15 years agoNios II - Data cache problem
Hi all, I'm using a Cyclone III DSP Kit (DK-DSP-3C120N) and uClinux. Some days ago I realized a working design which includes a Nios II processor characterized by only an instruction cache. Wi...
14 years ago --- Quote Start --- The data cache flush needs to be done with the same virtual address as the memory access itself - which means you'll need to do it from within the driver. The gcc 'asm' statement for the 'flushda' instruction is quite simple, you might find one if you search through all the header files. If your driver isn't using ioremap_nocache() to get a kernel virtual address for the phyiscal address, what is it using? I am presuming you are using the MMU - I can't remember if that requires the data cache. If you aren't using the MMU (so virtual and physical addresses match), setting the high address bit or using the defines that generate the 'io' forms of the memeory instructions would work. --- Quote End --- I'm not using MMU, so I don't use ioremap. I tried to use cache_push_all(), but it didn't works. Can you explain me how can i set 31st bit or where can I find the defines you're talking about?
