8 years agoNIOS Execute in place from EPCS flash
Hi, I am trying to load the NIOS code into EPCS and execute from EPCS. After compiling the code in Eclipse. I am getting the following error. address 0x3e09f88 of nios_hdmi.elf section `.t...
8 years agoHi,
I don't recall there is an option to define EPCS size in Qsys. If you are executing-in-place from EPCS, very unlikely your .elf will exceed the EPCS size, unless your application is really huge, or your EPCS is relatively small.
