14 years agoNios 2 to custom component communication
Hi, I'd like to know what instructions of Nios C program Do I need for writing and reading data to/from a custom component of sopc system??? I saw in some AN people use IORD() /IOWR() macros or...
14 years agoIf you haven't done yet, you need an Avalon MM slave wrapper, for example refer to the Avalon-MM Slave template you find here:
http://www.altera.com/support/examples/exm-list.jsp?cat=embedded You must connect your control signals to user_data registers bits, so you will control your block functions by writing or reading the related registers, like a common microcontroller peripheral. For example: user_datain_0 (control register) : bit0=start, bit1=reset .... user_dataout_0 (status register) : bit0=conf_code, bit1=packet_ready user_dataout_1 (data register) : connect to data_packet Regards
