8 years agoNios - Simple Socket Sever template - can't compile
Hello Altera Forums, I'm trying to compile the Simple Socket Server (RGMII) in eclipse-nios, but the compile fails to find these files: altera_msgdma.h altera_msgdma_descriptor_regs.h ...
GBeck
7 years agoI'm experiencing the same issue with trying to compile the Simple Socket Server example project using a Cyclone IV. Need to use Q17 or better to be able to use the EPCQ configuruation parts. Using an older version of Quartus is not an option. Replaced the SGDMA controllers with mSGDMA controllers. Must have not made the migration correctly since now the NIOS application crashes on configuring the Ethernet DMA descriptors. Does anyone have a reference design that successfully uses mSGDMA controllers using on-chip memory for the packet memory and rx/tx descriptors?
