8 years agoNios - Simple Socket Sever template - can't compile
Hello Altera Forums, I'm trying to compile the Simple Socket Server (RGMII) in eclipse-nios, but the compile fails to find these files: altera_msgdma.h altera_msgdma_descriptor_regs.h ...
8 years agoThe older design examples of simple socket server uses scatter-gather dma (sgdma) for the rx and tx interface with the triple speed ethernet (tse). However, the Simple socket server design template now assumes you used msgdma (modular sgdma) instead in your "Platform Designer", "Qsys", or "sopc builder," or whatever you want to call it. If you use the modular scatter-gather dma ip instead of the scatter-gather dma controller ip, it works in 17.1
