15 years agoNios - Problem to Read from DDR3
Hello everyone, I am working with the Arria II GX FPGA along with Quartus 10.1. I am trying to write data into an external ddr3 memory (2 gbits) using the altmemphy ddr3 memory controllers...
15 years agoIf this is a custom board (i.e. not a dev kit) then I recommend finding the datasheet for your particular memory device if it's not already listed in the memory presets. If you randomly picked some DDR3-SDRAM preset that doesn't match your own memory then you won't have much of a chance getting it to work without changing the timings manually.
Last but not least is your design meeting timing in Timequest? If not then that could be your problem.
