16 years agoNicheStack tk_crnos.h compiling problem
Hi there, I have problem compiling my NIOSII App SimpeSock Server under Cyclone3 (FireFighter board), I'm using NIOSII 10.0sp1 and i get an error in file: tk_crnos.h when i want to compile it. Err...
16 years agobut OS_EVENT is described in 'ucos_ii.h' file so i don't understand why program get error :( i need to do that ethernet connection for my engineer project:(
this is code of tk_crnos.h file, code which is provided by altera originally, and should work:
# ifndef TK_CRNOS_H# define TK_CRNOS_H
# ifndef CHRONOS# error - must define CHRONOS in ipport.h to use this file# endif
extern void TK_OSTaskResume(u_char * Id);
/* define the default priority for all net related tasks */# define NET_PRIORITY 0 /* not used on ChronOS */
# ifdef NOT_DEF
* Altera Niche Stack Nios port modification:
* OS_PRIO_SELF defined in ucosii.h, as is OS_EVENT
/* Self-ID token for pass to ChronOS primitives */# ifdef ALT_INICHE# include "ucos_ii.h"# else# define OS_PRIO_SELF 0xFF# endif /* ALT_INICHE */
# endif
/* Define the CHRONOS object control TK_ macros... */
/* macros for task type, entry, and name */# define TK_ENTRY(name) void name(void * parm)# define TK_OBJECT(name) u_char name# define TK_OBJECT_PTR(name) u_char * name# define TK_OBJECT_REF(name) TK_OBJECT(name)# define TK_ENTRY_PTR(name) void(*name)(void*)
# define TK_THIS TK_OSTaskQuery()
# ifndef TK_RETURN_ERROR# define TK_RETURN_ERROR() return# endif# ifndef TK_RETURN_OK# define TK_RETURN_OK() return# endif
* synchronization primitives
* Need one or the other of LOCK_NET_RESOURCE/UNLOCK_NET_RESOURCE and
* ENTER_CRIT_SECTION/EXIT_CRIT_SECTION. These should be implementable
* as either functions or macros, so we allow e.g. ipport.h_h to
* override these definitions by defining the names as macros.
* CHRONOS targets generally use LOCK_NET_RESOURCE/UNLOCK_NET_RESOURCE
* so we default to function declaractions for them.
extern void LOCK_NET_RESOURCE(int res);
extern void UNLOCK_NET_RESOURCE(int res);
extern void irq_Mask(void);
extern void irq_Unmask(void);
# define ENTER_CRIT_SECTION(p) irq_Mask()# define EXIT_CRIT_SECTION(p) irq_Unmask()
# ifdef NOTDEF
/* set up pointers to CHRONOS semaphores as void * so we don't
* have to include ChronOS includes in every file in the build. In Addition
* RXQ_RESID and FREEQ_RESID are not real semaphores, but just placeholders.
* See the LOCK_NET_RESOURCE() code for details.
*/# ifndef NET_RESID
extern void * net_task_sem_ptr;# define NET_RESID (net_task_sem_ptr)# endif# ifndef PINGQ_RESID
extern void * pingq_sem_ptr;# define PINGQ_RESID (pingq_sem_ptr)# endif# ifndef FTPCQ_RESID
extern void * ftpcq_sem_ptr;# define FTPCQ_RESID (ftpcq_sem_ptr)# endif# ifndef RXQ_RESID
extern void * receiveq_sem_ptr;# define RXQ_RESID (receiveq_sem_ptr)# endif# ifndef FREEQ_RESID
extern void * freeq_sem_ptr;# define FREEQ_RESID (freeq_sem_ptr)# endif
# endif
/* declare tasks which may need to be accessed by system code */
extern TK_OBJECT(to_pingcheck);
extern TK_OBJECT(to_netmain);
extern TK_OBJECT(to_emailer);
extern TK_OBJECT(to_ftpclnt);
/* map TK_ macros to CHRONOS: */# define TK_BLOCK() OSTaskSuspend(OS_PRIO_SELF)
extern OS_EVENT *rcvdq_sem_ptr;# define TK_NETRX_BLOCK() {
INT8U err;
OSSemPend(rcvdq_sem_ptr, TPS, &err);
if ((err != OS_NO_ERR) && (err != OS_TIMEOUT))
dtrap();
# define TK_SLEEP(count) OSTimeDly(count + 1)
/* (Id) is always of type TK_OBJECT_PTR */# define TK_WAKE(Id) OSTaskResume(*(u_char*)(Id))
/* (ev) is always of type TK_OBJECT_REF */# define TK_WAKE_EVENT(ev) OSTaskResume((u_char)(ev))
/* Do tk_yield() as a function to avoid pointless delays */
void tk_yield(void);# define TK_YIELD() tk_yield()
/* For ChronOS SignalPktDemux() is a routine which manually sets the net
* task to runnable. This is so we can call it from an ISR and not have
* ChronOS enable interrupts on us.
*/# define SignalPktDemux() OSSemPost(rcvdq_sem_ptr)# define SignalEmailTask() OSTaskResume(to_emailer)# define SignalFtpClient() OSTaskResume(to_ftpclnt)
# endif /* TK_CRNOS_H */
