14 years agoNicheStack TCP Client not working with some servers
I've been trying to talk to an Arecont IP camera via a TCP socket client on a BeMicro Nios2 app. The connection to the camera always failed to establish, although it was ok if I substituted t...
14 years agoThe camera is definitely to blame. It took me 5 seconds to search "arp rfc" on google and an additionnal 10 seconds to find the relevant paragraph ;)
Packet Reception:
When an address resolution packet is received, the receiving
Ethernet module gives the packet to the Address Resolution module
which goes through an algorithm similar to the following.
Negative conditionals indicate an end of processing and a
discarding of the packet.
?Do I have the hardware type in ar$hrd?
Yes: (almost definitely)
?Do I speak the protocol in ar$pro?
Yes:
Merge_flag := false
If the pair <protocol type, sender protocol address> is
already in my translation table, update the sender
hardware address field of the entry with the new
information in the packet and set Merge_flag to true.
?Am I the target protocol address?
Yes:
If Merge_flag is false, add the triplet <protocol type,
sender protocol address, sender hardware address> to
the translation table.
?Is the opcode ares_op$REQUEST? (NOW look at the opcode!!)
Yes:
Swap hardware and protocol fields, putting the local
hardware and protocol addresses in the sender fields.
Set the ar$op field to ares_op$REPLY
Send the packet to the (new) target hardware address on
the same hardware on which the request was received. Windows is know to be tolerant with lots of non conformities, which cause a lot of problems when hardware manufacturers test their equipment only with Windows.
