14 years agoNiche Stack - how to read dhcp address obtained from dhcp?
I am running SimpleSocketServer and cannot find where the IP obtained from dhcp server is stored? Thank you in advance
14 years agoIf you are using the Nios II console , you can see the DHCP address from the print out , somewhere between the "AutoNegotiation start" and "Simple Socket Server starting up ...".
