9 years agonewbie to SOCkit
Hello I'm working on system identification and signal processing. I'm gonna work with SOCKit+High Speed AD/DA Card. I've learned pure VHDL. my time is limited i'm very concerned about the future...
9 years ago --- Quote Start --- I didn't know that this kit is already obsolete. If you are not planning to use the HPS, you can consider boards that are non-SoC (FPGA only). Refer to this link: https://www.altera.com/products/boards_and_kits/all-development-kits.html and see if there is one that suits you :) --- Quote End --- http://www.alteraforum.com/forum/showthread.php?t=50835 I want to use Terasic ADA card with my future FPGA Board. http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=73&no=278&partno=2 if I want to sample the DATA and process the data simultaneously I will have many problem if I could I might buy an "Aria V GX Starter" but it is also out of stock!!! :confused: I know working with DDR3 is too difficult..I've seen Aria V has hardware memory controller.. so can I work with DDR3 RAM easily? due to my limited time. thanks
