21 years agoNew version of NiosII Flash Programmer
Hello, I'm reading the manual for the Nios II Flash Programmer User Guide, but it appears to not cover my software? On page 18, figure 1-3 shows options for "Program flash memory with softwa...
21 years agojoe,
Ok ... now I'm up to speed after reading the other topic. > I do not have a reset signal - only a watchdog reset input which I do > not connect to the programmer design, since I don't want to reset it!!! > So at the moment I just tie reset to vcc on the schematic? This is probably your problem ... I have a similar situation as you on one of my boards, so I dropped in a little delay counter that drives the system module reset_n. Here's what I use with the programmer design:module cpurst (
clk,
rsti_n,
rsto_n
input clk;
input rsti_n;
output rsto_n;
/* Counter width, delay is 1 << (cw-1) */
parameter cw = 9;
reg cnt;
always @(posedge clk)
if (rsti_n == 0) cnt = 1'b0;
else if (cnt == 0) cnt = cnt + 1'b1;
assign rsto_n = cnt;
endmodule You can just tie rsti_n to Vcc, clk to your device clk input and rsto_n to the system module reset_n. Regards, --Scott
