14 years agonetworking without OS Support
Hello , I am trying to run networking application without Uc/OS-II Support, (not using standard UDP_Offload or Super_Loop) for this i have choose the simple socket server server (RGMII...
14 years agoWhat do you want to generate?
The path to your clock in the .sdc file is absolute, so yes the compilation will fail if you change your top level file. You can try and use a wildcard on the beginning instead, i.e.*|the_enet_pll|the_pll|altpll_component|auto_generated|pll1|clk
