14 years agonetworking without OS Support
Hello , I am trying to run networking application without Uc/OS-II Support, (not using standard UDP_Offload or Super_Loop) for this i have choose the simple socket server server (RGMII...
14 years ago --- Quote Start --- I think there was a thread on this forum a little while ago about compiling the udp offload example on a more modern version of Quartus. You should try a search on the forum. --- Quote End --- Hello There, One Unique problem i have seen in this error , as i change the quartus version from 9.0 to 9.1 and 11.0 the requirement of Peak virtual memory increase. as in Q9.0 it says "Peak virtual memory: 395MB" as in Q9.1 it says "Peak virtual memory: 407MB" as in Q11.0 it says "Peak virtual memory:540 MB" (attached print screen of all three quartus version's) i have gone through the thread related to same issue, but don't find any clue though i have valid license for all above quartus version's. http://www.alteraforum.com/forum/showthread.php?t=19377 Regards kaushal
