14 years agonetworking without OS Support
Hello , I am trying to run networking application without Uc/OS-II Support, (not using standard UDP_Offload or Super_Loop) for this i have choose the simple socket server server (RGMII...
14 years ago --- Quote Start --- Up to MAC and PHY initialization, OS is not involved, since those are execute-once functions. You need OS features, superloop or any other interrupt scheduled process after inizialization when you really start sending and transmitting packets, especially if you need to manage a complex trasport protocol like tcp. --- Quote End --- I am working on UDP only for image data transmission. earlier i am using uC/OS-II along with NicheStack having 64k data cache and 64 k Instruction chache, each time server (image source)sends high speed data my nios-ii based Client says "No free buffer for Rx" even though i have increase TSE_MAC FIFO rx buffer to its maximum limit. so i plan to remove OS as it may taking lot's of space. and do the same exercise again
