15 years agonet-snmp mib files
Hello guys...... i using snmp in uClinux .....it works with the default mibs but i need to do my own mib file ....... anybody knows how can i do that???............ one exemple how can i m...
15 years agonz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c ../../../net-snmp-5.2.1/agent/mibgroup/snmpv3/usmUser.c -o snmpv3/usmUser.o
In file included from ../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:22:
/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/net-snmp-5.2.1/include/ucd-snmp/ucd-snmp-includes.h:7:2:# error "Please update your headers or configure using --enable-ucd-snmp-compatibility"
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:23:139: /home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/net-snmp-5.2.1/include/ucd-snmp/agent/ucd-snmp-agent-includes.h: No such file or directory
In file included from ../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:29:
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.h:19: error: syntax error before "var_ladProject"
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:59: error: extra brace group at end of initializer
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:59: error: (near initialization for `ladProject_variables')
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:60: error: `
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:298: error: 'write_ladAlarmLatching' redeclared as different kind of symbol
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.h:24: error: previous declaration of 'write_ladAlarmLatching' was here
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `write_ladAlarmLatching':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:303: error: `action' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:304: error: `RESERVE1' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:305: error: `var_val_type' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:306: error: `stderr' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:307: error: `SNMP_ERR_WRONGTYPE' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:309: error: `var_val_len' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:311: error: `SNMP_ERR_WRONGLENGTH' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:316: error: `RESERVE2' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:318: error: `var_val' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:324: error: `FREE' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:329: error: `ACTION' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:336: error: `UNDO' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:341: error: `COMMIT' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:346: error: `SNMP_ERR_NOERROR' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: At top level:
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:354: error: syntax error before "u_char"
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:360: error: 'write_ladAlarmState' redeclared as different kind of symbol
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.h:25: error: previous declaration of 'write_ladAlarmState' was here
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `write_ladAlarmState':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:365: error: `action' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:391: error: `ACTION' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:398: error: `UNDO' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:403: error: `COMMIT' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:408: error: `SNMP_ERR_NOERROR' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `var_ladProject':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:113: error: storage size of `string' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:115: error: storage size of `c64' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `var_ladAlarmTable':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:166: error: storage size of `string' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:168: error: storage size of `c64' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:57: warning: array 'ladProject_variables' assumed to have one element
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:57: error: storage size of `ladProject_variables' isn't known
nios2-linux-uclibc-gcc -O2 -g -fno-builtin -I../../include -I../../../net-snmp-5.2.1/include -I. -I../../agent -I../../../net-snmp-5.2.1/agent -I../../agent/mibgroup -I../../../net-snmp-5.2.1/agent/mibgroup -I../../snmplib -I../../../net-snmp-5.2.1/snmplib -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c ../../../net-snmp-5.2.1/agent/mibgroup/snmpv3/snmpMPDStats.c -o snmpv3/snmpMPDStats.o
echo timestamp > snmpv3/usmStats.lo
/bin/sh ../../libtool --mode=compile nios2-linux-uclibc-gcc -O2 -g -fno-builtin -I../../include -I../../../net-snmp-5.2.1/include -I. -I../../agent -I../../../net-snmp-5.2.1/agent -I../../agent/mibgroup -I../../../net-snmp-5.2.1/agent/mibgroup -I../../snmplib -I../../../net-snmp-5.2.1/snmplib -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c -o util_funcs.lo ../../../net-snmp-5.2.1/agent/mibgroup/util_funcs.c
make: ** Erro 1
make: ** Esperando que outros processos terminem.
echo timestamp > snmpv3/snmpMPDStats.lo
echo timestamp > snmpv3/usmUser.lo
nios2-linux-uclibc-gcc -O2 -g -fno-builtin -I../../include -I../../../net-snmp-5.2.1/include -I. -I../../agent -I../../../net-snmp-5.2.1/agent -I../../agent/mibgroup -I../../../net-snmp-5.2.1/agent/mibgroup -I../../snmplib -I../../../net-snmp-5.2.1/snmplib -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c ../../../net-snmp-5.2.1/agent/mibgroup/util_funcs.c -o util_funcs.o
echo timestamp > util_funcs.lo
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/build/agent/mibgroup'
make: ** Erro 1
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/build/agent'
make: ** Erro 1
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/build'
make: ** Erro 2
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp'
make: ** Erro 2
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user'
make: ** Erro 2
make: ** Erro 1
franz@franz-desktop:~/altera/linux/nios2-linux/uClinux-dist$ here an error what i did ........ i already add --enable-ucd-snmp-compatibility but doent work i guess.............. help.... :(
