8 years agoNeed help with debugging HPS
I need help with debugging SoC because I've been stuck on this point for nearly a week. In the past I worked extensively with FPGAs and microprocessors, so I have experience both in hw and sw. ...
8 years agoI don't like to answer to my own post, but after struggling one more day with the hardware and digging in the forum I eventually found a way to solve the problem.
I'm still not 100% sure everything is ok, but at least I can now run my baremetal application, blink the LEDs and read button status. I write here FYI the main points which fixed the problem; I hope this could help someone else. 1. Until this morning I tried to operate the DE0-Nano with the supplied SD card or with no card inserted at all: I was persuaded the latter should be the correct configuration. Then I found this thread (https://www.alteraforum.com/forum/showthread.php?t=56558) which suggested there could be is a hps boot problem when no SD card is connected; on the other hand the boot provided by the original SD card image (with Linux OS or whatever) brings the hps in a state not compatible with a baremetal application (I guess it activates a watchdog or any other OS specific feature) So I removed the supplied SD card and replaced with a blank one. Now the system is stable and I can load my application without errors. 2. The baremetal reference code I'm using includes "alt_printf.h" among the other hwlib related header files. I didn't investigate the reason, but including this .h file prevents the debug printf output to show on the app console panel.
