16 years agoneed help on dma
I have a custom logic wrote by myself. There's a DCFIFO in the logic. And when the fifo is full, NIOS II cpu will get an interrupt, then cpu will get(read) data out of the fifo. Every thing seems all right.
But when i use DMA to do the same thing as cpu does, I just can't get right data. The avalon mm slave interface of my custom logic is below. Could anybody give me someadvice?
rdclk <= csi_clk; --rdclk is the read clock of the dcfifo
process(csi_reset, csi_clk)
begin
if csi_reset = '1' then
rdreq <= '0';
else
if falling_edge(csi_clk) then
if avs_read = '1' and avs_address = "001" then
rdreq <= '1'; --rdreq is read request of dcfifo
else
rdreq <= '0';
end if;
end if;
end process;
begin
if csi_reset= '1' then
avs_readdata <= (others=>'0');
else
if rising_edge(csi_clk) then
if (avs_read = '1' and avs_chipselect = '1') then
if avs_address = "001" then
avs_readdata <= q; --q is output of dcfifo
end if
end if;
end if;
end if;
end process;
1 Reply
Don't use the falling edge, do everything on the rising edge.
You may want to configure your FIFO in showahead mode or add an extra read cycle on your Avalon interface. It could be a god idea to use a tool such as SignalTap to see what is happening on your Avalon slave interface.
