14 years agoNeed a fast way to insert ascii charts to Code
Hi, I'm using Terasic LCD TOUCH MODEL and I allready interfaced with the screen. I made a "putPixel(X,Y,Color)" function which enters a dot to the cordinate I choose on the screen. now...
14 years agoSearch the web for "font bitmap" or something along those lines, I'm sure there are some available. For the NEEK we used a script that would take a font collection and output .h files that contained arrays for each character. So if you wanted to use those ones go ahead. I don't know where the script went so you would be stuck with the ones we generated unfortunately. Designs like the C2H Mandlebrot design draws text to the screen so you can take a look at that font file, it's probably in the ballpark of 26pt but on that tiny screen the text is pretty small.
