8 years agomy first fpga hps
Hello, Im just trying to run my_first_hps_fpga but when I try to make in the shell there is an error I dont get where is the problem pleaase help me there is an attachement.
8 years agoNo you don't need linux, as long as you are using the SOC EDS shell it should work fine. Could you check out if SOCEDS_DEST_ROOT is set correctly in the shell? just write:
echo $SOCEDS_DEST_ROOT
