15 years agoMulti NIOS2 system Custom instruction opcode reuse problem in QSys
I'm currently using Qsys version 11.0, Build 157. Currently I have a system that consists of two NIOS2 processors and they are both connected to their own custom instruction component. As far a...
14 years ago@BadOmen
I run into the same problem. What do actually mean by separate subsystems? Two different instances of QSys system? I think this would be no good solution for me because I need the two NIOS to be sharing the same Avalon bus and with two separate instances this would be not possible, am I right ?
