15 years agoMulti NIOS2 system Custom instruction opcode reuse problem in QSys
I'm currently using Qsys version 11.0, Build 157. Currently I have a system that consists of two NIOS2 processors and they are both connected to their own custom instruction component. As far a...
15 years agoIt is also shame you can't select the number for each custom instruction.
If I have several custom instructions, I'd much rather use the a fixed number for each as it makes the compiler setup somewhat easier. I suspect you get a duplicate symbol problem if you have 2 (or more) nios that contain the same custom instruction (name & vhdl) with different numbers.
