9 years agomSGDMA ST-MM to SDRAM - Issue
Hey guys. I'm performing a design which contains a mSGDMA conected to a SoC SDRAM port. I could get it to write data onto the SDRAM by using a Modular SGMDA Dispatcher and a Write Master ...
9 years ago --- Quote Start --- However, have you had problems with this length thing? --- Quote End --- My problem was specifically related to burst transfers that required more than one burst. They just didn't work, in simulation or in hardware. Without bursts you're transferring single 16-byte words at a time (essentially a burst with one beat of data). If you try to transfer > 16 bytes then more than one beat of data is required, and that does not work. Sounds very similar to my problem. I hope you get to the bottom of this and can share what you find out. I highly recommend opening an SR (service request) with Altera technical support. I would have done that but we abandoned the design and moved on.
