Julien
7 years agomSGDMA MM to MM : issue reading from Avalon UART FIFO
Hi, On a DE0 Nano Soc I am trying to setup a DMA from a FIFOed Avalon UART IP, to the DDR3 memory of the HPS, under control of a NIOS processor. The UART is a Memory-mapped Avalon Slave, and the da...
FawazJ_Altera
7 years agoHello Julien,
Thanks for contacting Intel PSG Forum.
Have you seen this video?
https://www.youtube.com/watch?v=iaRkjkpMBH8
I gave a description on how to run mSGFMA and stream data from a source to a memory.
I did the mSGDMA to HPS DDR before. The first step I confirmed is, the data flow is correct (from source to on chip memory). Then, I changed the destination to HPS DDR. Please note that you would not be able to access HPS DDR until Linux is booting.
have you used the prefetcher mode?
