15 years agoMP3 Player
Anyone, can help on this code.
I really don't understand why there are some many files inside a folder? http://www.alterawiki.com/wiki/mp3_player3 Replies
I try to load the existing source code to NIOS II.
When i try debug it, there are error message come out. Anyone who know, please help? - Altera_Forum
did you compile the project first? Then if you select Run as Hardware it should find the .elf file for you.
Does it work with a simple hello world project? - Altera_Forum
Hi
I saw the same error when trying to run the project. The best solution: Create a new project and then add the source and header files from the MP3 player.
