14 years agomouting SD card on uClinux
I read the post about MMC/SD on altera wiki and followed this instruction but get this error
I used hardware of DE2_NIOS_HOST_MOUSE_VGA (DE2_Systemv1.6 CD), removed the components of SD (SD_DAT, SD_CLK,SD_CMD) in SOPC builder, then i deleted these lines: // All inout port turn to tri-state assign SD_DAT = 1'bz; // Set SD Card to SD Mode //assign SD_DAT3 = 1'b1; .out_port_from_the_SD_CLK(SD_CLK), .bidir_port_to_and_from_the_SD_CMD(SD_CMD), .bidir_port_to_and_from_the_SD_DAT(SD_DAT), *insert 4 lines code from wiki .MISO_to_the_mmc_spi (SD_DAT), .MOSI_from_the_mmc_spi (SD_CMD), .SCLK_from_the_mmc_spi (SD_CLK), .SS_n_from_the_mmc_spi (SD_DAT3), then generate and compile this projects after i used file system_0.ptf to make kernel and set config Device Drivers --> [*] SPI support ---> [*] Altera SPI Controller [*] MMC/SD card support ---> [*] MMC block device driver [*] Use bounce buffer for simple hosts [ ] SDIO UART/GPS class support [ ] MMC host test driver *** MMC/SD Host Controller Drivers *** [*] MMC/SD over SPI but when i boot with the SD card 1GB FAT, i see the messages mmc_spi spi2.0: ASSUMING SPI bus stays unshared! mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 676k freed (0x1f6000 - 0x29e000) but i can't see messages deteced MMC/SD or other messages mmc0: new SD card on SPI mmcblk0: mmc0:0000 TWTTI 124672KiB plese help me1 Reply
Please help me, i searched these post about this problem on forum but no resulst
