15 years ago
mount SD card problem
Hi
I want to mount SD card to /mnt
I follow the altera wiki http://www.alterawiki.com/wiki/mmcsd
But I can't mount successfully
When I boot kernel the information is
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
Built 1 zonelists. Total pages: 2032
Kernel command line:
PID hash table entries: 32 (order: 5, 128 bytes)
spi_read read data time out
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 5692k/8192k RAM, 0k/0k ROM (1695k kernel code, 715k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
SPI: Nios SPI bus device version 0.1
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.3 $
ttyJ0 at MMIO 0x838010b0 (irq = 0) is a jtag_uart
YOU have init Device 254
JELLO EXMAPLE INIT
TCP cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 588k freed (0x29b8000 - 0x2a4a000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
mount: Mounting none on /proc/bus/usb failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
And I can't find the mmcblk0 at /dev
How counld I solve it??
Please help me
Thank you very much
