14 years agoMissing NIOS II Menu on Eclipse
Hello, I have some problems in Eclipse (NIOS II) because I need to generate the BSP (right click on BSP part of the project->NIOS II->Generate BSP) and that menu disappeared. I can not find it aga...
14 years agoThe problem of disappearance of Nios II menu in Eclipse to edit and generate BSP (after you right-click on the BSP project) can be solved when you click on Window --> Open Perspective --> Other... --> Resource.
