14 years agoMissing NIOS II Menu on Eclipse
Hello, I have some problems in Eclipse (NIOS II) because I need to generate the BSP (right click on BSP part of the project->NIOS II->Generate BSP) and that menu disappeared. I can not find it aga...
14 years agoI've the same problem. I is gone without any reasons. Second time already, have seen this also with 10.1 and at that time I switched over to 11
I'm getting a little bit tired of the Altera tools... often the USB-blaster is not recognized and you have to click it many many times before it recognise and the programmer sometimes crashes when files are missing. The Eclipse environment does not show the NiosII menu anymore and also sometimes the Run As hardware disappears.... Very very frustrating
