8 years agoMissing NIOS II Hardware in run configurations
Folks, I have inherited a mature design from a previous project. The target is a DE0_nano, with a NIOS II/f processor in the design. My qts version is 11.1, fully licensed, windows 10 env. ...
8 years ago1. Try from Debug As ->Debug configuration and select the NIOS II hardware.
I have tried that, there is no NIOS II hardware selection in the RC menu 2. Eclipse toolbar window-> Open Perspective->check if Nios II is the default if not ->Other and change to Nios II. When I open the Nios II perspective, little changes. There is also the Nios II Debug perspective. It has a different window organization but still no debug. 3. Run Nios II Eclipse as Administrator. Check post from caridee http://www.alteraforum.com/forum/showthread.php?t=30848 I did this like the the article suggested. Still no Nios II hardware to debug. I know running as admin took effect because all of the file explorers that come up in eclipse have the CWD in the quartus bin directory Thanks, Ed
