8 years agoMissing NIOS II Hardware in run configurations
Folks, I have inherited a mature design from a previous project. The target is a DE0_nano, with a NIOS II/f processor in the design. My qts version is 11.1, fully licensed, windows 10 env. ...
8 years agoHi Ed,
--- Quote Start --- What is missing is a NIOS II target when you right-click on the application in the project explorer, mouseover Debug As. --- Quote End --- 1. Try from Debug As ->Debug configuration and select the NIOS II hardware. 2. Eclipse toolbar window-> Open Perspective->check if Nios II is the default if not ->Other and change to Nios II. 3. Run Nios II Eclipse as Administrator. Check post from caridee http://www.alteraforum.com/forum/showthread.php?t=30848 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
